How to make multiple plots for each channel
I am using a NI cDAQ-9178 and third party DAQ. The forum has many post that have answered part of my question. I would like to plot Frequency, Temperature and Voltage for 12 channels. I am currently plotting all three, but don't know how to plot these for each channel. I will attach the huge file, if necessary ... but will post screenshots for now. Here is a screenshot of my front panel for two types of graphs/charts and my block diagram. I have an array of the channels which displays each individual value for Frequency, Temperature and Voltage ... I just don't know how to switch between the channel plots. Any suggestions are welcomed ... thanks. I started with the following link: http://digital.ni.com/public.nsf/allkb/21E8163F259DA2058625703B007511AA).  .
(4,241 Views)
Hi mzlhb,
so you already know how to index one channel/row of each array.
To index 12 rows one after the other you should use a loop - an autoindexing FOR loop would be ok too…
Btw. when setting plot properties you should first set the active plot, then it's properties! Properties are handled top-down!
(4,221 Views)
And, Setting Plot visibility that way is just plain silly.
Right-click the Plot Legend and expand Visible Items check the "Plot Visibility Checkbox"
"Should be" isn't "Is" -Jay
(4,208 Views)
Thanks for that information, Jeff·Þ·Bohrer. I am still new to LabView and did not know that the plot visibility was available by simply right clicking.
(4,164 Views)
Thanks GerdW. I have already separated the Frequency, Voltage and Temperatures into channels using an auto-indexed FOR loop, outlined by the red rectangle in the attached photo. I am currently using these arrays to print to a text file. I just don't know how to use this to change the plot to display the frequency, voltage and temperature for each channel. It's possible that it is working when I increment/decrement the row's control, but I am not seeing any changes in the plot. I'm not sure why I made these 2d arrays 😞
(4,162 Views)
Jeff·Þ·Bohrer,
I don't think that many are aware of the right click for plot visibility feature, as I got the idea that you've called "silly" from a forum post, "how do I display multiple plots on one chart?" The attached referenced vi that I've used was from altenbach, KNIGHT OF NI. Thanks for educating myself and others on this feature though.
(4,159 Views)
