How to make front panel as Generic
Hi all ,
I need to know that how to do front panel reuse.
Here i am using two front panel to do some work .
But both the front panel do the same work ,
I need to use create one front panel make them as generic .
I C#  can able to do front panel generic .
In labview how to do it .
It helps me lot ..
Thanks in advance .,
(3,365 Views)
You can group the controls as a Cluster and make a type-def of it. That's probably what you're after.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,362 Views)
Hi ,
Can please modify it..
And send to me ..
if you dont mind ..
(3,358 Views)
Hi ,
No need ... thanks a lot ...
(3,349 Views)
