How to make a vertical Power Spectrum graph?
I need help to rotate a graph 90 degrees. My input is Scaled Data which goes into an Index Array to split the channels. The graph is okay for the selected channel but is in landscape mode and I want it to be relatively thin and vertical i.e. exchange the X&y axis.
(2,900 Views)
How about, switch the leads to the graph.
(2,900 Views)
I may not understand exactly what you need, but I have a suggestion.
The trick is to reformat the data and use an XY graph. They allow for ultimate control of the displayed data because they just draw lines between the x-y points in their data array. I suspect the scaled data in your VI is in a cluster. Unbundle it, autoindex the array with a for loop, bundle in a "x value", pass the array of clusters to the xy graph.
(2,900 Views)
Thank you Jeremy. I rewired it by switching the x and y terminals. Much easier and faster. I don't know if there will be repercussions.
Cheers,
Raymond
(2,900 Views)
