How to make a global array by shift register
You are right, of course. I was trying to quickly answer the enquirer's questions without knowing exactly what he or she is actually after.
Message 11 of 27
(1,809 Views)
May I know how to make the one iteration loop?
Message 12 of 27
(1,798 Views)
Just use a while loop with the termination condition set to terminate (via a diagram constant). It will run once per call.
Message 13 of 27
(1,794 Views)
The correct way to do a functional global variable or action engine.
Note that the Read case just wires through the case and would not actually be broken.
Message Edited by Ravens Fan on 12-10-2007 09:15 PM
Message 14 of 27
(1,793 Views)
Sorry, I still cannot make it in 8.5
Message 15 of 27
(1,776 Views)
As I said, you don't even need a loop in LabVIEW 8.5. Just use a feedback node and wire as I showed above.
What problems do you encounter?
  1. Add controls and indicators
  2. place a while loop
  3. add shift register
  4. wire a TRUE diagram constant to the termination condition terminal.
  5. wire the data wires as shown
Message Edited by altenbach on 12-11-2007 06:15 PM
Message 16 of 27
(1,773 Views)
Thanks, I just using the feedback node for the 1st time.
Message 17 of 27
(1,763 Views)
I want to build a 1D Array where each element is being entered manually. The new value has to be inserted, unless the value has not been previously inserted. And i have to display that array.
Cand someone tell me how to do it ?
Message 18 of 27
(1,241 Views)
Use an event structure to capture when a new value has been entered.  Use a shift register to hold your current array.  When a new value is entered, use the Search 1D Array to make sure that the new value isn't already in the array.  The search function will return a -1 for the index if the element was not found.  If not found, use the build array to add the new value.
Message 19 of 27
(1,236 Views)
Homework time again? 😉
Instead of adding to an existing 5 year old thread that is only marginally related, you should start a new thread. Then you should also be more precise on what you mean.
The term "insert" has a very special meaning in LabVIEW, and implies that it should go in an exactly specified location in the existing array (as opposed to "append" or "prepend", where it always goes to one of the ends). However, you are not specifying where the new element should be inserted (e.g. keep the array sorted, at the beginning, at the end, etc.). Please be more much specific.
This is a very basic exercise. What you have you tried so far? Where did you get stuck?
Message 20 of 27
(1,219 Views)
