How to make a .exe without errors about the costum scaling
Hello everybody,
i'm new with Ni-Labview,
i'm trying to make a .exe file of my application, this is working perfect, but if i make costum scales in my Daq Assist options and i make the vi in a .Exe then there are always errors if i open it on another computer... if i put every Daq Assist box to the ''no scale'' option, then the exe is working on another computer...
it is working good on the computer where i build the vi on...
but of coarse i'm not planning to put the hole software (labview) on that other computer... that's where the .exe file is for i guess...
i have 1 Daq Assist that is programmed with a scale that converts 0-5 volts to 0-3000(rpm)  this is a output voltage
and the other daq assist box is programmed with a scale that 0-1volts is 0-3000(rpm) this is a input voltage
everything is working like i want it to work on my computer where i build the application, but if i make a .exe file of it, including all the Daq Mx drivers and so on then this file is not working.... so i made a error box at the end of the daq assist to see what is happening and if i open it then on another computer then it tould me that there where errors with the scaling i made... but i don't see the problem????
is anyone having this problem also? or maybe i do something wrong????  i really don't know how to solve this problem... and it should not be that hard,... i'm sure of it....
hope someone could help me....
i use a Ni-USB 6211
thanks for reading this and hope to hear something soon!
thanks
Kind Regars,
Kris
Message 1 of 12
(4,367 Views)
Are the scales part of the project or in MAX? If they are in MAX, then when you build your installer, choose the option to export the hardware configuration. Then when include that in the installer, it will be imported on the other pc.
Message 2 of 12
(4,353 Views)
hello there everybody,
dennis told me to put reply's in the thread, i'm sorry that i did't, ... i understand that this is better for other people with the same problem to find out quicker...
@dennis:
i have found that the scale's are saved in MAX
i'm gonna try your suggestion of saving the project with hardware config....
i will post later if it worked out!!
Thanks man!
kind Regards
Message 3 of 12
(4,326 Views)
Hello KV,
Everything ok now?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 4 of 12
(4,298 Views)
Yes everything working fine now.... But i have to make the scales again by myself in max because it is not doing this with the installer yet... But i solved it....
Thanks for all the help.!
Kind regards,
Kris
Message 5 of 12
(4,283 Views)
Ok!
Thanks for letting me know!
If anything pops up, then just let us know!
Kind Regards,
Message 6 of 12
(4,269 Views)
Hello There,
i have one more question that i can't figure out....
i have a vi in attachment that you can open hopefully....
in the block diagram you see 1 Dial, this is the left dial in the screen... now this is the setpoint of the PID regulator..
what i want is a Analog input to be the Setpoint of the PID Regulator Also... i prefer to have little button or something so i can choose what i use , or the Dial on the computer(with the mouse)  Or a Analog input from external device 0-10V input
i have try'd a lot of things but the only thing that is everytime popping up:
Possible reason(s):
NI Platform Services: The specified resource is reserved. The operation could not be completed as specified.
i can't solve it..... is there anybody who have an idea how to put things straight and working?
Thanks!
Kind Regards,
Message 7 of 12
(4,257 Views)
Hello KV001,
This should for sure be possible.
I can open the VI, but one thing is unclear:
Which Analog Input do you want to use as setpoint for the PID?
Is it the one that's currently read out through the DAQ Assistant?
The simplest idea I have is just to use the "select" node to allow you to switch between a manual and an automatic mode.
Another question:
Which loop period should you obtain?
Kind Regards,
Message 8 of 12
(4,238 Views)
Hello ThiCop,
I don't put the daq assist in yet... i have to do the same daq assist box and then i want to have the orange Dial that is connected to the Setpoint now to be still connected, but also the new daq assist box need to be connected some how....
i don't understand what you mean with a select node??
also the loop period ?
could you please make me an example with 1 more Daq assist box and then how you should connect it so it should work? then i can try it out realtime here with my Usb 6211
Thanks for helping!
Kind Regards
Message 9 of 12
(4,229 Views)
Hello KV,
Let me rephrase the questions:
- Which analog input channel should be used for defining the setpoint?
Is this AI0, AI1, ... ?
- The select node is a simple "block" in LabVIEW that allows you to select between two different values of any type dependent on the state of a boolean input (true or false).
- Loop period: How fast should your loop be executed?
Kind Regards,
Message 10 of 12
(4,224 Views)
