How to make a color gradient in numeric indicator
How can I make a color gradient based off of a value in an indicator box.
Say I want the BG color in the indicator box to go from a value 50 and be blue, then turn towards red as the value climbs to 200(200 being solid red).
I haven't managed to get any kind of color change so far. Don't know what I'm doing...
(4,748 Views)
1. You are reading the property, so you will not be able to make a change. You need to write to it.
2. You need to do it in the loop otherwise it will just happen once.
3. You probably want to use the background color.
(4,738 Views)
Can I convert that VI to 2014 somehow?
(4,708 Views)
Accepted by topic author LabNoob14
(4,705 Views)
Thanks! This will take me a little bit to figure out, but it helps a lot
(4,696 Views)
