How to make EXE file from LabVIEW
I am looking to make an EXE file from a (nice and sinple) VI i have written.
Can anyone point me in the correct direction, i have attempted this myself but to no avail.
Alos with a EXE file does the PC i'm running it on require LabVIEW Runtime Version?
I have attached the VI for information.
Thanks ROss
(2,565 Views)
The application builder is in the tools menu as Build Application or Shared Library (DLL). If this choice is not there then you do not have a full development system. You can purchase the application builder serarately.
Yes, you need the LV Run Time libraries loaded on any computer that is to run a .exe file created with LabVIEW. You can include the LVRT with an install by clicking on the Installer Settings Tab, make sure there is a check mark in the Create Installer box, then click Advanced. Make sure there is a check mark in the box for including the Run Time Installer.
Rob
(2,565 Views)
