How to made multiple selected value boxes in GUI
I am writing a program that users can put a check mark on several boxes for input voltages (like 0.6v 1 v 2 v 3 v).The seleted voltage will be looped into an Vset vi. Does anyone has any idea how to make this?
Thanks!
Message 1 of 12
(4,120 Views)
I would use a listbox with a selection mode of 1 or more
"Should be" isn't "Is" -Jay
Message 2 of 12
(4,116 Views)
Thank you! Jeff.
That's what I want.
Tianshu
Message 3 of 12
(4,101 Views)
Thank you, Is done with Kudos. That's what I want, is marking the post solved. welcome to the forums. it helps others search for similar solutions. I'm glad I could help.
Message 4 of 12
(4,092 Views)
Don't forget that you were initially talking about checkboxes. You can easily change the listbox to "show symbols", then change the symbols to a  checkmark for each selected element.
Message 5 of 12
(4,052 Views)
Accepted by topic author tian66
Message 6 of 12
(4,045 Views)
Very appreciate this answear!
Message 7 of 12
(3,988 Views)
Of course my example is very primitive and just shows the idea. In real life you should use an event structure to update the control only when things change. Also the selection color needs to be set only once at the start of the program or even be saved with the VI and not set at all programmatically after that.
Message 8 of 12
(3,982 Views)
How Can I read each value from the listbox? I found the value coming out from the listbox is the index but not the actual elements.
Thanks!
Message 9 of 12
(3,972 Views)
Just use the array of selected indices and index into the array of item names. Wrap a for loop and you'll get an array of all selections.
Message 10 of 12
(3,968 Views)
