How to lock my app.
I have make a app with LV6i RT and a want to make work only in one
machine. It is possible ? How.
(2,938 Views)
To lock your application is not something that is easily done with native LabVIEW code (impossible?).
However, if you are using LabVIEW under Windows you could use the VI I attached below (the VI is written by Shaun Rumbell). It makes an API call and returns the serial number for the drive you specify (e.g. c:\). Use this number to verify that the user is using your program from the machine(s) it was supposed to be used from. Hope this helps. /Mikael Garcia
(2,938 Views)
