How to link pdf's to show in Start Menu
I need to build and installer for LV10 to put a project on a target machine.  I want the exe to show up under the all programs tab.  Not too hard yet, but I also want to list certain documentation files under the exe so the user can just as easily pull up the instructions or the like from there.  I don't seem to find anyway to do that directly within installer.
(2,741 Views)
Accepted by topic author thouston@iccnexergy.com
Never mind.  I was suffering from cranial rectumitus.  You simply go to the shortcuts section.
(2,738 Views)
A few tips-
Typically I deploy to target and ship systems so I havn't tried all of this but....
The installer can be configured to run a application after installation (and I assume Open >>Acrobat has a active x or command line hook)
The build can also contain a vi starting with the keyword "About" where About vi is configured as a "splash screen"  See Darren's Nugget here
Edit: Thanks to autosave This was still on my profile when ut failed to post.
Or, you can target a shortcut if thats what you wanted in the first placeSmiley Very Happy
"Should be" isn't "Is" -Jay
(2,730 Views)
Thanks for the additional info.  As usual if you really want to do something in LV, you can normally find at least a couple of ways to do it.
(2,726 Views)
