How to link my access database to ODBC?
kavi
Message 11 of 40
(2,104 Views)
-2147217900
kavi
Message 12 of 40
(2,103 Views)
Hi mike,
I tried to rename a table 'data' to 'Names'  using the vi attached .
It results with an error -2147217900
kavi
Message 13 of 40
(2,098 Views)
Hi kavi,
is it a new "problem"? Can you now create your mdb file within LabVIEW.
Mike
Message Edited by MikeS81 on 07-01-2009 01:09 PM
Message 14 of 40
(2,097 Views)
s mike.I cant do it.
kavi
Message 15 of 40
(2,092 Views)
karpaga wrote:
Hi mike,
Hi kavi,
you have to use a SELECT and a DROP command, because Access has no rename command.
See the attached image.
Mike
Message 16 of 40
(2,089 Views)
Thanks a lot now i can create mdb and open connection .its working!
kavi
Message 17 of 40
(2,085 Views)
I can rename a table.Thanku mike
kavi
Message 18 of 40
(2,077 Views)
hi,
 im new to labview.. now i have a problem in creating a database.. im using labviw 7.0... so for creating database i download labsql toolkit... and database toolkit..  i know some basic command in sql.. so i used labsql... but what is the problem is i dont know to use that toolkit in labview 7.0.. by seeing thread i knew  'll get answer for my problem..
my project is to check the pins pcb.. for example consisder 4 pins .. im applying sine,traingular,sawtooth and square for the 4 pins.. now i want to store the output pin in database for the further process.. can u help me...
N. Srinivasan
Message 19 of 40
(1,974 Views)
hi,
 i created .mdb file  and i connect with System DSN...i want to know that whether u used labsql or database tookit....
i attached the format of the table should be saved in database.........
N. Srinivasan
Message 20 of 40
(1,974 Views)
