How to limit string length
Hi
I would like to write a code to let the user type a certain text length into a string box. How can I do that?
(4,859 Views)
A solution could be (if isn't too complicated in your case) to use an event structure.
Unfortunately this approach has its flaws...see the little vi attached.
regards,
manga
(4,846 Views)
You can also set the control setting 'update value while typing' on and check the string length in a while-loop. It's not nice but it works
(4,838 Views)
This version has a little correction...
bye,
manga
(4,813 Views)
Hi Manga,
One issue with your VI appears when you paste text into the string control. That way there's a risk that the limit might be exceeded. Check out other threads that does take that case into account, for example this one:
Restricting text entry in string control to say 10 chars
Have fun!
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(4,798 Views)
