How to limit size of an array?
I only want a carton that can hold 12 eggs. I don't need an infinite amount of egg. If you want that, maybe it's a good solution for you. But that's not what I'm seeking
Message 11 of 36
(3,191 Views)
@User002 wrote:
This is my first week with labVIEW, so I'm a little confused
This is not a LabVIEW problem.
LabVIEW is a very powerful programming language and a good programmer can do anything with it.
You can initialize an array with a given number of elements and replace them one by one or you can auto index at the output tunnel of a for loop to create that array. Either way, the compiler will know the final size and allocate accordingly. You don't even need to worry about that.
Really fixed size arrays are important in special cases (FPGA!) Where LabVIEW supports that fully.
Message 12 of 36
(3,189 Views)
That is not the problem I was asking about. If you forget what I was asking already, you can reread the original post. If you can't or don't want to answer, that's fine. I'm not here to argue about what you'd rather do. I'm just here to see what I can do using my sets of constraints. I prefer less replies if you can't contribute to the conversation
Message 13 of 36
(3,186 Views)
Hi chuck,
I want to build an array of a certain size by loops stopping when the array is full.
array = []
repeat
 append element to array
until arraysize=12
 Some pseudocode.
Keep in mind: building an array using BuildArray and a shiftregister is less efficient then what Altenbach suggested initializing an array and replacing one element after the other), especially when array sizes grow larger!
(When you want to improve your LabVIEW skills you also should take care of such sugeestions…)
Message 14 of 36
(3,165 Views)
Can this method filter out data I don't want in the array though?
Message 15 of 36
(3,162 Views)
Hi chuck,
IF condition is met
ENDIF
Again some pseudocode: only append elements when your condition is met!
Message 16 of 36
(3,165 Views)
Wouldn't that be using Boolan logic?
Message 17 of 36
(3,132 Views)
Hi Chuck,
How else do you want to implement a decision in software when you don't want to use a comparison function and a case structure?
You want to collect data conditionally, but you don't want to implement that condition???
Why don't you use boolean wires???
Message 18 of 36
(3,130 Views)
Because that's not what I'm asking. If you can't answer my question as I asked, you don't have to respond. I'm taking altenbach's method instead
Message 19 of 36
(3,126 Views)
Hi Chuck,
Which involves checking a condition. See how far you get when you hesitate to implement condition checks...
Good luck!
Message 20 of 36
(3,122 Views)
