How to keep/latch a value
I am trying to design a simple vi to update a indicator's value in the 1st condition, and keep the indicator's value the same (latched) in the 2nd condition. I tried to use a simple formula node and it doesn't work. The indicator always reset its value to zero in the 2nd condition. Can anyone help me to achieve this function ?
Charlie
(2,127 Views)
I would just not use the Formula Node.  You can use the Greater? primitive to do the comparison and a Select primitive to choose the value to set to C.  I would also store the C value in a Shift Register so I could use the value in the FALSE case of the Select.
(2,113 Views)
Hi crossrulz,
Thanks a lot for the suggestions. The Shift Register is the magic and it works !
Cheers,
Charlie
(2,082 Views)
Also, you should use native structures instead of the formula node. One option was the Select node mentioned earlier the other would be to use the Case structure.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,073 Views)
