How to interface scanner in labview
Hi all,
I have one HP scanjet scanner and I want to interface it with PC through LabVIEW. Is there any idea to develop some code for it?
(2,739 Views)
What is the goal for this request?
I doubt that many people have experience with using scanner devices in LV.
Worst case: It is not possible at all.
Best case: HP provides a well documented API (e.g. DLL) which you can directly call from LV. So you would create a couple of VIs which "wrap" the desired DLL functions for further usage in your application.
Norbert
Norbert
Expert: Geometry
(2,718 Views)
what about using the TWAIN-API shipped with Windows? All functions needed are available in the twain_32.dll.
Tyler
Certified LabVIEW Architect
(2,716 Views)
