How to interaction with Main VI from .Net event callback
Here are attached some files to achieve this (not mismatching that time).
Nelval 已写:
@nathand wrote:
@Nelval wrote:
Hm I tried to make it work but seems it does not... any reason, why?
It doesn't work because you took the main VI from my example, and the callback from SteveBale's code. One uses a named queue, the other uses a user event reference passed as a parameter to the callback. Or, put differently, your main VI waits for a user event that never occurs, and your callback puts data into a queue that's never dequeued. Pick one method or the other consistently.
Yup I noticed that.. later, the fact is that you provided your own main and provided the old callback version that's why I was a little bit surprised cause the methods were mismatching, anyway I like the user event generation, a bit more consistent with the Event Structure
Message 11 of 14
(2,794 Views)
Oops! Sorry about that. Looks like I originally posted the right screenshots but the wrong VI, and when I replied to you I only looked at the screenshot and your VIs. Interesting that it took 4.5 years for someone to notice that I messed up.
Message 12 of 14
(2,772 Views)
Can you attach saved in LV9.0?
thanks!
Message 13 of 14
(2,656 Views)
Here you go.
Message 14 of 14
(2,643 Views)
