How to integrate NI Vision Builder and Lab view 8.0
Hi to all.,
    I want to integrate NI vision builder and Labview.... Please give me the idea and procedures to be followed........
(2,589 Views)
Hello Tec-sol,
Are you using the Vision Builder for Automated Inspection? If you are, then you can create LabVIEW code. In the configuration interface go to Tools>>Migrate Inspection to LabVIEW. To do this you will need to have the Vision Development module installed.
Or are you using the Vision Builder? Depending on the version of the vision builder you are using you can also generate LabVIEW code.
If you want your code to run in LabVIEW I would suggest that you create your code with the Vision Assistant (this has replaced the Vision Builder, and ships with the Vision Development Module). The Vision Builder for Automated Inspection is intended to be a standalone application.
Jasper S
(2,575 Views)
