How to install NI-DNET driver 64-bit ?
The 32 bit should under "C:\Program Files (x86)National Instruments"
 the 64 bit should under "C:\Program Files\National Instruments".
when I install LabView 2012 (64-bit) under "C:\Program Files\National Instruments", it asked for installing the device driver. When I put the disk of device driver (Q1 2014), by default it will install under "C:\Program Files (x86)\National Instruments". I cannot change it to "C:\Program Files\National Instruments".
How did you make this work, using LabView 64 bit but the DNet driver (VI) still in 32 bit ?!
(2,737 Views)
There are only a handful of 64-bit toolkits. You can try copying the 32-bit folder. I don't if the toolkit uses 32-bit DLLs. If so, you'll have to use 32-bit LabVIEW.
(2,729 Views)
I found this page so I guess I cannot do it in 64 bit since the table stated “Not supported” for the 3 items I needed: NI-DNET, NI LabVIEW Real-Time Module and NI LabVIEW FPGA Module
https://www.ni.com/en/support/documentation/compatibility/09/national-instruments-product-compatibil...
(2,683 Views)
