How to install LVIFA_BASE in ARDUINO UNO.
I am using arduino uno with LABVIEW 2012 EVALUATION VERSION. I had installed LIFA in my win7. I want to control servo motor using LABVIEW . I had put the sketch of LVIFA_BASE.pde on arduino software. Then i uploaded LVIFA_BASE on arduino. I open the code for controllingservo in labview. and run. It shows ERROR 5002. please tell me how to use LVIFA_BASE and control servo and d.c. motors from LABVIEW using arduino. arduino>>>file>>> open>>> LVIFA_BASE_2.1.1.69>>> LVIFA_BASE.pde>>> ????????? what to do next. and how to control using LABVIEW
(5,262 Views)
what next  i will do after i upload LVIFA_BASE as arduino sketch.
 i am attaching a snapshot of problem . I don't know what to do next
(5,246 Views)
Looks like he's opted to continue this one Gerd. I'll put a duplicate notification on the second thread.
Chakslord: The latest version of LIFA is 2.2.0 which was updated 31 Aug 2012 to include support for LabVIEW 2012 - are you sure that you are using this latest version? (probably not, looking at the changelog on your screenshot). Update your LIFA version and hopefully this will solve the issue you are seeing.
An easy way to keep up to date with new versions is to use VIPM.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
(5,235 Views)
Hello everyone..
i had installed LVIFA_BASE ...i want to control peristaltic pump just for switch on and off it by using arduino Uno and labview 2012...
i want to control 3 units peristaltic pump...can anyone suggest me what components should have and how labview code look like???
also should i need external power supply??if yes...what is that??
i'm very desperate to know it to my project....
please someone help me...
below i had attached a link for specification of my peristaltic pump...
http://www.alibaba.com/product-gs/650912637/dc_12v_dosing_peristaltic_pump_OEM2.html?s=p
(5,079 Views)
