How to insert signals into multiple columns in db, dbtoolset
I have  a labVIEW program that is currenly simulating voltage and a current signal using the DAQ Assistant. I'm using the database connectivity toolset. I am currently able to insert one signal into the database converted to a float(I can insert both into the same column as bianary but it needs to be stored as a usable format and in seperate columns.)
The problem I am having is at the DB Tools Insert Data block. I have the connection, dbTable, error code, and create table boolean being passed into it. Where I am a little lost is how to set the columns I want to store the multiple signals into.
If someone could break that part down for me that would be great. In short, I want to store voltage(channel0) and current(channel1) from the DAQ Assistant into their own respective columns in the db.
(2,745 Views)
As I have often pointed out, the easiest solution to this situation is to dump the Database Connectivity Toolkit. Check out this thread and follow the references in it. If the DCT weren't in the way what you are wanting to do would be very easy.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,740 Views)
