How to insert 1D array elements into specific place in 2D array
I have 2D array of color boxes [10x10], and i would like to replace elements with elements from 1D array [4 elements] at specific place.
When i trying to use ,,Replace array subset" i can only specify ROW INDEX or COLUMN INDEX where to start putting new elements. But i need to select both column/row index.
Any ideas?
(3,532 Views)
Accepted by topic author kamill
Hi kamill,
when replacing a 1D array in a 2D array LabVIEW can only replace row- or columnwise.
When you want to replace specific, but independent elements you need to use an autoindexing FOR loop to iterate over the elements of your1D array(s)!
(3,521 Views)
Thanks, everything works now 🙂
(3,500 Views)
