How to input data from Excel in a Labview table?
CC:
For some reason that I couldn't find the Vi that you sent me does not do what is supposed to do. That is, if I try to copy and paste something in or from the table it only takes the very first cell...
(unzipped al the folders and extracted the files in the same folder).
Maybe I'm missing something?
RPJ
Message 11 of 18
(3,009 Views)
RPJ wrote:...I try to copy and paste something in or from the table it only takes the very first cell...
Did you select first the range of cells you want to copy by clicking on the first cell and shifting to the last cell ?
CC
Chilly Charly    (aka CC)
Message 12 of 18
(2,996 Views)
Yes, I did; but let me try that again. Maybe i forgot to extract something or I shouldn't have extracted the llb files as I did. Once I'll give it one more try I'll let you know.
Radu
Message 13 of 18
(2,993 Views)
Well, I believe I've tried everything (I know) but it is still not working...
Maybe something else should be in the code?
RPJ
Message 14 of 18
(2,977 Views)
Hmmmmm...
Here is another version with everything inside, that should work better !
CC
Message 15 of 18
(2,950 Views)
Thank you.
Now it works fine. I gave it best rating.
Radu
Message 16 of 18
(2,926 Views)
Hello CC - thank you for this post of Copy Paste .zip. I am a new user (using V8.0 with Vista) and I'm trying to copy from Excel and paste to a Table. This VI looks like what I need, but I get the following when I run it:
Possible reason(s):
LabVIEW:  Specified property not found.
Property Name: Value (Signaling)
I open Excel and then copy some data and then select Paste in the VI menu and get the above. Thanks for your help.
JLV
Message 17 of 18
(2,587 Views)
I found the error that you were having trouble with as i had the same problem.  the author just misclicked Val(Signalling) and if you right click on the property node where it says that and just select Value it will work.
Message 18 of 18
(2,480 Views)
