How to indicate range on graph.
I would like to indicate an acceptable range of
values on my xy graph. The x axis is force and
the y axis is displacement. At the end of the
test, the force should be between 40 and 50 lbs.
I would like to put some sort of markers or
cursors to indicate this range. Is there some
way to draw on a graph? I tried to overlay a
bitmap image without much sucess.
Bert
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,507 Views)
The easiest way to do this is make the graph a multiplot graph.
Create a bundle that contains the plot of the limits.
Send the data to one node of a Build Array and send the limits to the other
send the multipot to the graph. Now you have visible limits on the plot.
Kevin Kent
(3,507 Views)
Very cool, That is the answer to something I gave up on. It worked perfect.
Thanks Kevin.
Henry
(3,507 Views)
Hi, I had to put markers on my XY Graph so I used the
attribute node and the cursor list attribute to put time markers on
the x axis. I'm still looking for a way to control the fonts but it
did allow me to put a line on the chart showing time.
Steve Drake
(3,507 Views)
