How to increase the speed of video (avi file) using labview
How to increase the speed of video (.avi file) using labview? I have  tried this by skiping alternate frames. also I have used  minimum time delay.Is there  any other option for which i can go?
please suggest me...........
(2,988 Views)
Are you using NI Vision IMAQ AVI Read Frame or anther method to read the AVI file?
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,976 Views)
YES,I am using NI Vision IMAQ AVI Read Frame to read the AVI file.
(2,964 Views)
To play the AVI faster you have to use a higher rate in reading then it was recorded with, that's all.
Have a look at the "Read AVI Example.vi" which uses "IMAQ AVI Get Info.vi" to read the original frames per second the AVI was recorded with.
Christian
(2,955 Views)
Thank you...........
(2,951 Views)
