03-28-2010 01:21 AM
hello LV
I need advice following
1. To the sine signal of 100 data (100 sampling) to sort 250 rows in the array. It changes the sine signal in the plane that time.
2. To set up a new row by external trigger signal.
Thank you
03-28-2010 07:23 AM
Hi Nusorn,
Your question makes little to no sense. Could you explain further, perhaps send some example code of what you have done so far?
Rgs,
Lucither
03-31-2010 07:44 AM
In my work
Sine wave 10 cycle in 1Hz(sampling= 100). i want to frist cycle in the array row 1 and secound cycle in the array row 2. Add rows as cycle increasing and value of cycle is still at that row
04-01-2010 11:53 AM
Hi nusorn007,
Do you have a VI with what you have tried already? I think we would be able to assist much better if we saw the code you have tried. Thanks!
