How to increase rate at which data is written to file?
I have a program that reads data at 200kHz and I would like the program to write the data at the same rate. However, the fastest I seem to be able to get my program to write is about 5kHz. I have been using the DAQmx Read and the Format into File functions to read and write the data.
I have tried moving the write function into a separate loop, so that the data would write to a file after the data collection was complete. However, this did not change the rate at which data was written to a file. Any suggestions for increasing the rate at which data is being to a file? Thanks for looking over my problem!
(3,610 Views)
Instead of writing one value at a time, save up 100 in an array or long string and write the whole block at a time.
Les Hammer
(3,610 Views)
Well, writing to a file is always slower since it takes some time to access the hard drive. I noticed in your program that you are writing into an ASCII file. That is also slower than if you write to a binary file. There are several examples that ship with LabVIEW that allow you to do High-Speed Datalogging (I actually believe that is the name of the examples). Those examples actually come in pairs, one does the datalogging, and another helps you read the file. I will recommend taking a look at them.
The previous suggestions by Les Hammer is a great idea. Instead of acquiring 1-sample at a time, try acquiring 100 or 1000 samples and write them to the file.
I hope that helps!
GValdes
(3,610 Views)
Thanks - your suggestions have been very helpful!!
(3,610 Views)
I am trying to collect in-cylinder pressure data using the program i have. this program is only collecting 130 data/sec in excel file.
Now how do i ncrease this rate as i want to collect 3000data/sec in excel file.
Any help would be highly appreciated.
Amit
(3,250 Views)
But you will only be able to record just over one minute of data using Excel at that sample rate before you hit the 65K line limit, I would look at using something other than Excel - Mike
(3,221 Views)
