How to increase frequency resolution in power spectrum?
@James-D wrote:
Hi Ashokan,
It looks like the inputs to the two functions are in line with each other. Have you performed any other experiments with the two functions? As in, have you tried changing the input parameters to both cases (still keeping them the same) to see if this difference in dB level is consistent?
He cannot, the matlab function always returns result in dB / frequency bin.
Ashokan,
you need to do some own research about this one. I would start with taking some simple well described data, some sinusoid, that you generate in one of those environments, save it to a file and run it through another one, beware of saving in different datatype. Use some simple setting (no window, no overlap, some reasonable Data length - 1024, same FFT length as data and so on).
Message 21 of 21
(602 Views)
