How to include the NIWebAppServer.conf when building a web service installer in LV2010
Hi all,
I'm build a LabVIEW 2010 web service and creates a deployable setup installation as described in Web Services FAQ:
http://zone.ni.com/devzone/cda/tut/p/id/7747#toc12
but also would like to include my .conf file for the NI Application Web Server. The file is located in:
C:\Program Files\National Instruments\Shared\NI WebServer\NIWebAppServer.conf
This is where all settings (listening ports, SSL, users etc.) are configured.
If I look in LabVIEW 2009 build instructions for web services:
http://digital.ni.com/public.nsf/allkb/62B9C2D5C91EE8B28625778800609FF2?OpenDocument
they include this file, but it is a new procedure in LV2010 (as seen in the top link) and I can't seem to get this conf file included and installed on the deployed system automatically for LV2010. Today, I must copy it manually.
Any ideas of how to do this?
Mattias
(2,738 Views)
Having the same problem, even if pointing the installer to install the particular file, the installer will install its own some default file. Did you find any solution?
/Carl
(2,513 Views)
