How to import CAN .dbc files to Labview?
I am using NI CAN 8473 which supports Frame API only,
In this case can I please know how to import .dbc file into LabVIEW.
Also do I need to change channel API to frame API for this process ?
Any example will be helpful.
(3,404 Views)
Hi wilburwu,
In this case can you please let me know how I can import .dbc file into LabVIEW.
(3,405 Views)
Hi @VikashKumar23 ,
Have a look at this KB
How Can I Use the NI-CAN Channel API with USB-CAN Hardware? - National Instruments
It should solve your issue.
Kind regards,
Joelle
(3,355 Views)
