How to ignore warnings from Matlab when I run it in mathscript
I am running a Matlab code in Labview in a loop. It happened that under certain conditions the Matlab code shows repetitively a warning and automatically this leads to crash LabVIEW.
Is there a way to stop Matlab execution and output , for instance, zero to Labview before starting an iteration in Labview loop in the aim to avoid Labview crash when the warning appears?
PS: I noticed the warning when I run the script directly in Matlab as Labview crashes before showing any error.
Zied
(3,737 Views)
Hi Zied,
This question would be better suited for a forum discussing that software--you should get your external code working without errors or warnings before trying to run it in LabVIEW.
Nick
(3,684 Views)
