How to idenify comma as data in CSV file
I have a CSV file having data containing comma (,) in it.
So whe i read the file as the data contain(,) the data is read as two different value.
Can anyone suggest any idea or is there ay VI available to overcome this problem of having (,) as data for CSV file.
Anticipating response.
Message 1 of 14
(7,907 Views)
Hi Alex,
Give a try using spread sheet string to array function and making delimeter as ,(comma). I think it will work out..
LV 8.0, 8.6, 2011,2012,2013 WinXP
Message 2 of 14
(7,904 Views)
By definition, a CSV file has data separated by commas. That means you can't have commas in your data. Some implementations (Excel, for instance) allow you to have commas in your data if you wrap the data in double quotes (so 1,2,"3,4",5 will result in 4 columns) or escape it, but LV doesn't recognize that. You can see some more here - http://en.wikipedia.org/wiki/Comma-separated_values
The easiest thing to do is to use another delimiter and not call the file CSV. If you want to fix the existing file, you can probably open it in Notepad, put quotes around the relevant data, then open it in Excel and replace the commas with another character.
___________________
Try to take over the world!
Message 3 of 14
(7,889 Views)
Are your "CSV" file data stored with a fixed number of bytes per field?  Can you look at the file and *know* that the comma is data and not a delimiter?  If you can know it, you can write a program to figure it out.  Perhaps you can show us some sample data and explain why a particular comma isn't a delimiter and we can help.
Jim
Message 4 of 14
(7,877 Views)
I am having the same issue. I have a CSV file that is comma delimited. One of data columns has value which contains a comma, but this data is wrapped in double quotes. I am using the Read Delimited Spreadsheet VI to parse the CSV data. However LabVIEW 2017 doesn't properly read the data because the value contains a comma, but this value is wrapped in double quotes.
Is there a solution to this issue without having having to the change the delimiter of the CSV file?
Message 5 of 14
(7,547 Views)
The only thing I can think of is to "pre-process" your data by reading the text and using "search and replace" in a judicious manner.  Then use the "Spreadsheet String to Array" function to parse it all out.
Bill
CLD
(Mid-Level minion.)
Message 6 of 14
(7,538 Views)
Depending on how well formatted the file is, it can work with ", " (comma, space) as delimiter.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 14
(7,531 Views)
Great Zombie Discussion, i.e. broughT back from the DEAD.  lol.
It's a crying shame there isn't an input on the read delimited spreadsheet string VI that accounts for numbers with commas that are surrounded by double quotes.
Saving XLS files to .txt, or tab delimited, is truly the way to go.
I do like the idea of using  [   ","    ] as the separator, or even [   ,"   ] followed by a replace double quotes with nothing approach.  But, as said ...  the data has to be well behaved.
I guess it only comes as a problem when the data file is not 're-savable' from csv format to tab delimited format.
Would love to chase this down but have bigger fish to fry, so to speak, at the moment.
Mark Ramsdale
Message 8 of 14
(7,487 Views)
As long as it's well behaved there's really no problem, but if it's less so, e.g. a different amount of spaces, you'll have to use some cleaning. E.g. a regular expression search of \"(^\")+\" (if I managed to format that correctly, regular expressions is the closest thing to magic I know. ^^
/Y
Qestit Systems
Message 9 of 14
(7,473 Views)
So I try to fry this little fish...
Greets, Dave
Message 10 of 14
(7,463 Views)
