How to hide cursor name in cursor legend with LV 8.2
I don't know if it is a LV 8.2 OSX bug
but it seems to be impossible to hide the cursor name in the cursor legend
I just wand to show the 2 values of the cursor
and always see the name of the cursor
if i erase the cursor name, leaving it empty, i see a yellow (highlighted) square which can't be erased
do somebody have any experience about this point ?
Message 1 of 8
(3,580 Views)
Can't you just grab the column divider between "Cursors:" and "X" and move it to the left boundary?
Message Edited by altenbach on 10-27-2006 01:31 AM
Message 2 of 8
(3,575 Views)
no, i forgot to indicate one condition :
all the decorations are transparent !
i don't want to see anything but the values
Message 3 of 8
(3,569 Views)
Hi Pibee,
I think you need to build your own, esp. in 8 you have the cursor value change event!
Ton
My LabVIEW Ideas
Message 4 of 8
(3,567 Views)
How about something like this.
Message Edited by Jhoskins on 10-27-2006 10:14 AM
Joe.
"NOTHING IS EVER EASY"
Message 5 of 8
(3,553 Views)
first, it's easy to hide the cursor name if there is no cursor !
i took your ctl,
hided everything possible
and set the colors of every object to transparent
and look at the result
there is still a yellow square behind the x value
Message 6 of 8
(3,539 Views)
Looks like you want to be perfect. You will have to build your own VI. I would suggest building an XControl. I have attached a VI that you may want to look. Instead of using the built in cursor list I just created one of my own with two cursors and made evrything transparent.
Joe.
Message 7 of 8
(3,528 Views)
thnak you for indicating me that the cursor move event was there now
i waited for it since years
but it doesn't give answer to this problem
how can you avoid the highlighting of the cursor name ?
Message 8 of 8
(3,485 Views)
