How to graph acquired data?
You can convert the Dynamic data to waveform data type with the appropriately named Convert From Dynamic Data function. If you use the Get Waveform Components, you will see that a waveform is a kind of cluster with a t0, dt, and Y array. You can create your own timestamp array from this with a for loop and a shift register or the Get Waveform Time Array function.
And please, no more large pictures. The easiest way to get help is to post the actual VI.
Message 11 of 11
(530 Views)
