How to get voltage output
I am trying to write a simple 9233 single channel program. I have a FPGA program and a host VI that I have placed in my project explorer. For some reason I get a constant .0026 volts from the output of my 9233 channel. I don't know why the data is not being collected and displayed on the graph. Would anyone be able to help me? Here are the programs.
(3,182 Views)
Hi Jimmy P,
There is a good example using the 9233 in the Example Finder that demonstrates how it's typically used.  For example, because of the "Data Rate" property, it's unnecessary to use a loop timer in the acquisition loop (this information is in the Help files for the 9233 as well).  Also, the FPGA Start I/O is usually used as well.  Take a look at the example as a starting place and work from there.  Hope this helps!
James R.
(3,113 Views)
