How to get the old position and save it
Hello everyone,
i attatched a simple VI  which does the following: it gives the mouse position in pixels when i click the mouse in an image.
My question is: I need to continuously save the last position was clicked in a variable, and then subtract the new position (when a new click occurs) from the old position. can anyone please help how to do this?
I would be very thankful for any help 🙂
Thank you in advance
(1,606 Views)
If you need to keep a record of what happened in the last iteration of a loop, you should use a shift register.  There was a really good example called Draw Graph with Events or something similar that would help you understand this.  NI took it out of the example finder though.  If I find my old copy I will post it for you.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(1,595 Views)
Thank you for your reply.
i tried it with a shift register but somehow im not getting the result i need, which is to subtract the new value when another click occurs from the old value 😕
(1,583 Views)
Accepted by topic author AymanB95
I managed to solve it by using shift registers and saving the values to an array.
thanks again
(1,563 Views)
Great!  Glad you figured it out.  I did find that old example.  Guess what?  It builds an array of coordinates that hold all the points in the graph just like you did.  Check it out...
NOTE: The example is old (2010?) but it opened in my 2019 so I saved it for that.  Let me know if you can't open it.  I used this example to start many programs where I needed to draw in an XY graph (like thermal profiles, etc.).  It's got some useful ideas in it even though it's a small program.  I don't know why NI dropped it from the examples.
(1,520 Views)
