How to get the list of database Views modifying the DB tools list tables.vi
I have a problem, I just started using LabVIEW and in particular the LabVIEW connectivity toolkit and I am lookig fgor suggestion regarding how to get the list of database Views modifying the DB tools list tables.vi...
Thanks in advance,
Michela
(2,937 Views)
Hi Michela,
since the VI you want to modify is part of a Toolkit, I suggest you to copy the whole block diagram in a new VI and then save it in a new location.
  1. Place the DB List Tables.vi on a block diagram, double click on it and go to the tab "Window -> Show Block Diagram "
  2. Select "Edit -> Select All" to select the whole block diagram and select "Edit -> Copy"
  3. Open a new VI and select "Edit -> Paste"
  4. Save the new VI
In this way you can modify everything you want without overwriting the Toolkits VIs.
Hope this can help.
Andrea N.
Principal Applications Engineer - Semiconductor EMEA
National Instruments Italy
Certified LabVIEW Architect - Certified TestStand Architect
(2,915 Views)
OK, so I understood how modify a toolkit vi creating a copy of it. Great.
But my question was different: what can I do to get the database View list instead of the table list?
Michela
(2,896 Views)
