How to get the current windows username
To get the real VI path, also if you make an EXE from it, use the flowing setup :
This will always get the correct path to the application.
Message 11 of 12
(2,106 Views)
That's not anymore true for applications built with the post 8.0 executable file format. Here the VIs can and often will get stored inside the exe with deeper path structures and then this VI will not report a correct path.
Rolf Kalbermatter  My Blog
Message 12 of 12
(2,095 Views)
