How to get table border using Excel Report Toolkit.
Hi
I am using Excel Report toolkit on LV 7.1
I am using Excel Easy Table.vi to insert the table data. The problem is that i am not
seeing any border setting to this table. Some default table format are available which can be wired
to the Excel Easy Table.vi , but the table border and style does not come out as what i expected.
I tried using Excel Cell format, to put a border to the table, but the border is put for every cell in the table.
I want only the outer border for the full table. how to do this.
I do not want to use macros.
thanks Hema
(3,194 Views)
Im not sure what type of table border you are aiming for, but with the Report Generetion Toolkit, you can use the 'Set Excel Color and Border' vi to set your table border. If you only want the outside border, make sure that in the 'Inside Border' cluster the 'ON/OFF' boolean is set to OFF and that you correctly specify your 'Start' and 'End' cell co-ordinates.
Hope this helps.
(3,188 Views)
