How to get mechanical action (Latch or switch) of a boolean control from property node ?
Hello all
I use a code to get all the controls from the front panel, in order to read them or get their references etc...
If I have a boolean control in latch mode on the front panel i receive an error (you can't read the value of a latch : error code 1193) and i want to avoid that.
I want when I scan through controls to avoid to ask the value of a boolean in latch mode, but I can't find, in the boolean control property node or method, its mechanical action.
Does anybody knows a way to retrieve that information ?
Thanks !
(4,663 Views)
What version of LabVIEW are you using? If you enable the scripting VIs in LabVIEW 2010 (in Tools -> Options) then there is a "Mechanical Action" property available.
(4,660 Views)
Accepted by topic author YoannG
For non scripting, the crude way that works is to use a property node, read the value then write the same value, if an error is generated (code 1193) you know that the button is latching.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,647 Views)
