How to get external exe exit code in LabVIEW 5
Hi, I'm trying to figure how if it's possible to get the exit code when calling an external executable from LabVIEW v5,
Thanks.
(3,287 Views)
If the external application you're running is a command-line program or function (like "ping" for example) you can simply call it such that any data returned to the command line window is written to a file. From within LV you can then read the contents on this file to extract the response. For example, the command line:
ping ftp.ni.com >> c:\test.txt
will ping NI's ftp site and write the result of the ping to the file test.txt in the root directory of the C drive.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,287 Views)
Thanks Mike, I've actually solved my problem.
Piping the output of an executable doesn't actually give you the exit code though.
(3,287 Views)
Hmm, after delving into Windows API I was able to answer this myself.
I was using a "Run Application.vi" (lvwutil??) & this has a dll call to "GetExitCodeProcess". The last call of this function will return (as the last parameter) the Exit code for an executable.
I hope this helps someone - & if I have any more questions I'll answer them later 😉
(3,287 Views)
