How to get entire date information with NI FTP tool?
Hi everyone, I have encountered a problem about retrieve file information via NI FTP tool, I want to get the entire date information such as:01-01-1904 00:00:00. But it seems not possible to get all information with 'FTP Directory Listing.vi' in NI FTP toolkit. It only provides part of them. for example:Mar 27 13:14 or Apr 09 2014. Could you please give some suggestion about this? Thanks a lot.
Message 1 of 11
(3,740 Views)
attached the snapshot for your information.
Message 2 of 11
(3,739 Views)
Hello panzer099,
can you tell me how you can display the date in "dd/mm/yyyy"?
I only receive "mmm dd hh:mm".
Thank you
Message 3 of 11
(3,620 Views)
Hi Marcoh,
you can dive into the inner guts of the FTPDirectoryListing function.
So you can put a probe on the data that the "LIST" command reads from your FTP server: does that server even send the full date/timestamp information as requested?
Message 4 of 11
(3,596 Views)
Hi GerdW,
thank you for your reply. This is the whole String which I receive: "-rw-r--r-- 1 ftp ftp 5 Jul 08 13:29 Test.txt".
Message 5 of 11
(3,568 Views)
Hi marcoh,
so you can parse the received string on your own when the NI routines don't provide the answer you expect!?
Message 6 of 11
(3,560 Views)
Sorry Gerd, I don't get it.
Message 7 of 11
(3,554 Views)
Hi marcoh,
When the FTP server sends the correct data, but NI's implementation of the FTP VIs does not parse the data correctly then you might create your own "FTP List" VI which does provide the correct data.
Use the existing NI implementation as a guide line when you create your own copy of this VI!
Message 8 of 11
(3,545 Views)
It seems to work when I receive the file info from an older File (one year ago). Then the format is mm dd yyyy.
Furthermore I will test your way. Thank you!
Message 9 of 11
(3,542 Views)
It's definitely a server side issue. The FTP protocol was originally developed for command line operation. The parser on the receiving side for the List Directory command supposedly was meant to be a human, and humans are surprisingly good at guessing the correct thing from incomplete or changing information. So the actual formatting was not strictly defined and mostly just tried to be the same as whatever the according ls (Unix list command) would produce.
Could it be that these files are then on different volumes somehow? It seems that the older files get listed according to a different locale than the newer files. The locale on Unix based systems is the combination of country and language specific settings for numeric and date//time formats. There is nothing LabVIEW can do here for you. The problem is at the other side with the FTP server.
Rolf Kalbermatter  My Blog
Message 10 of 11
(3,500 Views)
