How to get detailed header/comment information when reading a .wav file
Hi there,
I am looking for a way to get the .wav header/comment detailed information when reading in a .wav file.  I need details like initial time of measurement and scale information that is found in the comment.  I am currently using the open/read .wav vis in labview and I need more than sampling frequency, and bits/sample.
Any help would be appreciated!!
Thank-you.
(3,322 Views)
Hi pa,
why do you use WAV files to save measurement data?
Why not use TDMS functions, which support saving metadata???
(3,311 Views)
The external device I am using only exports in .wav format.
(3,308 Views)
This is what you have to work with.  I suppose you'll have to consult your equipment manual to see what maps where.
Bill
CLD
(Mid-Level minion.)
(3,295 Views)
Thank-you,  I guess each .wav has its own variable structure within that framework.  I will see what I can come up with.
(3,292 Views)
