How to get data only on a single period from function generator
Thank you for replying so soon. By average waveform, I mean the average of the first data point, then the second data, etc...just like you said. For example, I run 500 times, then average these 500 waveforms to one to get rid of noise. Your explaination is really helpful, but it is hard for me to follow... i just start to learn Array in labview..Can you modify my code a little bit so that I can see what you really did?
Weiye
Message 11 of 15
(1,129 Views)
You could also do it this way.
17683i64A95B051FCFF517
Tim
GHSP
Message 12 of 15
(1,129 Views)
Have you considered zero phase shift data filter.
Tim
GHSP
Message 13 of 15
(1,125 Views)
Weiye
The code is already in its most simplest form.  You need to learn Labview better.  Look for free online tutorials on the NI website.
- tbob
Inventor of the WORM Global
Message 14 of 15
(1,113 Views)
I didn't see the image you attached on your last post before. I tried later and It works the way that you suggested. Thank you so much! The problem is solved!
Message 15 of 15
(1,086 Views)
