How to get connector pane output programatically
Hii Every one,
Actaully in my application i need to know in a sub vi connector pane what are the terminals connected to it.
for example simple addition.vi with 2 i/ps and 1 output..
i will connect the 3 variables in the connetor pane......
then from another vi i need to know what data is available in that addition.vi connectpr pane?? how to get it?? can any 1 explain me....
Message 1 of 10
(5,215 Views)
Hi Karthikey...,
what do you mean with "... what are the terminals connected to it."? Do you mean the type? Can you explain a bit more about what you try to do?
Which type do you use as input (Variant)?
Mike
Message 2 of 10
(5,211 Views)
Hii Mike
In a sub vi i connect different i/p's and o/p's like string,number(like I 32,double)etc....
Now i want to know what r the i/ps and o/ps connected in the connector pane with data types for each........
Message 3 of 10
(5,207 Views)
Hi Karthikey...,
so you have lots of inputs and outputs with different types and you want to know which are connected?
This thread discribes how you can check if an input is connected or not:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=406234&jump=true
You can also use variant inputs, or an array of variants and use the "openg" function to get the connected type.
http://wiki.openg.org/Get_TDEnum_from_Data
Mike
Message Edited by MikeS81 on 05-07-2009 08:53 AM
Message 4 of 10
(5,203 Views)
sorry mike i cann't understand can u explain me clearlyy
Message 5 of 10
(5,197 Views)
Hi Karthikey...,
which part do you mean? Is it correct that you have different inputs and you want to know which of them is connected? Can you explain why you need it? Maybe a polymorphic vi is the better solution for you.
Mike
Message 6 of 10
(5,184 Views)
ok using polymprphic vi how to get the solution for this???
Message 7 of 10
(5,181 Views)
One way to do it, is to go to help in the toolbar. Then use "search the Labview help", or "find Examples" option. Just seach for polymorphic
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 8 of 10
(5,179 Views)
Hi Karthikey...,
navigate to "File -> New...". There you can select a polymorphic vi. Add all the your different vis and that's it.
Mike
Message 9 of 10
(5,171 Views)
Maybe it is rather leading to the desired result if you explain why you need to know this programmatically.
I asume that you are rather new to LabVIEW and miss some of the very basics of this language. I encountered such questions like yours only from programmers coming from C++/C# or other OOP-languages.....
Norbert
Norbert
Expert: Geometry
Message 10 of 10
(5,168 Views)
