How to get computer to recognize Uniblitz shutter driver
I am having trouble getting my Uniblitz VCM-D1 shutter driver to be recognized by the computer/labview. I have it connected through a RS-232, but I can't figure out how to install the software driver. According to Uniblitz, they don't make any drivers for this (which I find strange) and I have to go to NI to do this.
Any help or tips would be appreciated.
(3,047 Views)
You don't connect a software driver to an RS-232 port. You connect an instrument. NI does not have a driver for any Uniblitz instrument so I don't know if you found a driver someplace or are asking how to create one. And, a serial instrument is never detected by a computer or LabVIEW unless you write a very specific program to do so. Please provide some more details on what you are trying to do and the exact nature of your problem.
Edit: Part of the confusion is that the Unitblitz name is 'shutter driver'. So, there is a need to differentiate between software driver and the hardware itself.
(3,045 Views)
A quick look at the manual says that a LabVIEW driver is actually available and it's exactly where the manual says it should be.
(3,040 Views)
Hi Dennis,
Thank you for your helpful information regarding serial connections. And yes, in the future I will specify between the software driver and hardware driver, as that is a necessary distinction.
My communications with Uniblitz have led me to believe that the software provided on their site is not the actual driver software to connect to LabView. However, I have downloaded the VIs and have posted them to the upconversion board and will try them out as soon as they are in a workable version.
Again, thanks for your help.
(3,008 Views)
