11-21-2011 03:53 AM
Hi
I am using Labview2010 and NIUSB6009 for aquairing data. I need to have both Analog1D waveform and
Analog 2D DBl from DAQmx Read.vi. i am doing continus sampling.
any idea how to get both types from DAQmx Read.vi?
thanks
Solved! Go to Solution.
11-21-2011 05:33 AM
If you are acquiring the data from one channel at a time then you will probably get 1D array of waveform. If you want to acquire the data from several channels at a time then you should get 2D array contains all information from channels.
If I am right, You can not get both the data types(1D and 2D) from from DAQmx read function. I haven't heard this. This is all what I can expect.
11-21-2011 07:22 AM
Your question does not make much sense. Whu do you think you need both? You can easily acquire multi-channle data as a 1D waveform and convert to a 2D DBL if you want. Just use the Get Waveform Components inside a for loop.
11-21-2011 09:00 AM
11-21-2011 09:05 AM
Still don't understand what you are doing. Be aware that with the 2D dbl, you lose the timing information.
