How to get a Remote GPRS Terminal IP address?
Hi
I want to build a server to get remote sensor data through GPRS DTU, APN bind SIM card.
want to use remote DTU IP address to distinguish the remote site!
Is it possible?
Best regards.
Alex
(3,618 Views)
you might need some wireless device listed in the link below:
https://www.ni.com/en-us/support/model.wsn-9792.html
(3,496 Views)
It's not entirely clear what you're asking for but if I've understood correctly...
As far as I know, most mobile carriers share IP addresses for mobile data - so there could be multiple devices using the same IP address. I think you would be better off trying to use some other parameter (e.g. Serial Number / MAC address / programmed 'identifier') to identify the unit/location that is sending the data.
(blog)
(3,482 Views)
