How to get Variant Info programmatically?
Colleagues, very simple questions: How to get Variant Info (which is visible in the Variant control placed on the front panel) programmatically?
See screenshot below:
it should be simple solution, but I can't found it...
Yes, I know about \vi.lib\Utility\VariantDataType, but parsing whole structure is hell... Especially when I will have cluster in cluster, etc...
Any idea?
Thank you in advance,
Andrey.
(3,558 Views)
You should check out the OpenG Variant Configuration File VIs. They do all the hard work of parsing the variants.
___________________
Try to take over the world!
(3,546 Views)
Actually, it is the LabVIEW Data Tools  (oglib_lvdata) library that you probably want.
(3,540 Views)
Also see this recent thread for similar discussions.
(3,529 Views)
