How to get MultiSim 10 Update
After i installed the Education Eval and ran the "check for updates" thingy, it says that there is a critical update "suu90147.exe" and it even gives directions on how to download it. but when i follow the link there is no "download" button. where is this "critical" update???
Message 1 of 8
(10,400 Views)
It looks like you are using the Multisim 9 evaluation.  You will not be able to download the update for this version anymore because it is no longer on the webpage.  You should download V10 instead, you can this version at the following link:
http://www.ni.com/academic/multisim/
Tien P.
Message 2 of 8
(10,386 Views)
i just downloaded the eval yesterday from that link you provided. when i run NI Multisim it says v10. so now what?
Message 3 of 8
(10,380 Views)
can anyone tell me how to get this update? i've already had some issues with the program, but i'm not sure this update will fix (or maybe it will).
Message 4 of 8
(10,372 Views)
Multisim 10 is the latest version, there are no updates for that version.  If you start Multisim 10 and the Support and Upgrade utility tell you there are updates, then you should uninstall the old SUU.   Go into the add/remove program utility and remove EWB support and upgrade utility, version 10 has a new utility.
Tien P.
Message 5 of 8
(10,367 Views)
i only installed what came with ver10 eval, i dont have any "EWB" in my add/remove list.
Message 6 of 8
(10,356 Views)
I am having the same problem when I downloaded and installed NI Electronics Workbench Group Version 10.0.1 Software (250MB) for Professionals.  Brand new install on a system with no previous versions of Multisim (Circuit Design Suite) installed (though I do have LabView and LabWindows).
Message Edited by hoffmmd on 10-03-2007 11:36 AM
Message 7 of 8
(9,833 Views)
Circuit design 10.0.1 is the current version there is no update for it.  When you are in Multisim, select Help>>About Multisim the product version should indicate 10.0.343.   If the version indicates something else, you are not up to date.  You can download the current version at: ftp://ftp.ni.com/support/circuitdesignsuite/10.0.1
Tien P.
Message 8 of 8
(9,810 Views)
