How to get Labview RT to Display a Front Panel on the Graphics port
I suspect that this post belongs on the feature request board but I'll ask anyway.
Most of my systems require a seperate PC for a SCADA/HMI/User interface linked to the RT controller using Network Published Shared Variables.
I understand that Remote Panels and Web Interfaces are also an option, bu still requires a PC to Access them.
I use high end RT controllers such as PXI, CRIO, and of 3 hours ago Desktop PC's.
Each has a DVI or VGA port connected to a graphics processor.
What I would like to be able to do is display my main VI front Panel to a connected monitor.
A possible solution is to use a windows OS but it is no good for a precision realtime system.
Any thoughts?
iTm - Senior Systems Engineer
uses: LABVIEW 2012 SP1 x86 on Windows 7 x64. cFP, cRIO, PXI-RT
(2,933 Views)
I did not use it, but maybe you're looking for the RT Hypervisor?
http://sine.ni.com/nips/cds/view/p/lang/en/nid/207302
This only works with PXI, though.
(2,918 Views)
Thanks Dan, this is good information.
I am not sure it is exactly what I am after but is certainly in the right direction.
"A bipolar controller."
It does sound like overkill to install windows to display a front panel though.
Tim L.
(2,911 Views)
Tim,
I don't think there is another way to display anything else than text on a RT screen.
Maybe that's something for the RT idea exchange, but I would not expect that to be implemented soon.
What about a webinterface designed for Tablets and Smartphones? That way at least you don't need another PC to see it.
Daniel
(2,908 Views)
Dan,
As above, Web interface still requires additional hardware of some sort.
Apple is a closed system so loads of prlems with 1/2 the market,
I am warming up to the hypervisor, I just don't like the idea of it taking out an entire core (on a dual core system). And needing a windows licence to go with it as well.
A quad Core PXI puts a gaping hole in my budget, makes a second PC not seem so expensive.
Would be great if I could get it on a Desktop, quad cores are pretty cheap now.
(2,878 Views)
